Windows Service with WCf
09 Dec 2014 09:52 #2555 by support
Replied by support on topic Windows Service with WCf
We do not have an out-of-box example for the combination you described.
As a proof of feasibility, in the examples solution for C# and VB.NET, we have a very simple WCF service project (called Web\WcfService1), and a client to it (called Console\WcfClient1).
The service contract:
using System.ServiceModel;
namespace WcfService1
    // NOTE: If you change the interface name "IService1" here, you must also update the reference to "IService1" in Web.config.
    [ServiceContract]
    public interface IService1
        [OperationContract]
        string GetData();
The service implementation:
// WcfService1: A simple Web service using WCF technology. Provides a GetData method to read a value of an OPC item.
// Use WcfClient1 project (under Console folder) to test this Web service.
    // NOTE: If you change the class name "Service1" here, you must also update the reference to "Service1" in Web.config and in the associated .svc file.
    public class Service1 : IService1
        public string GetData()
            var easyDAClient = new EasyDAClient();
            object value = easyDAClient.ReadItemValue("", "OPCLabs.KitServer.2", "Demo.Ramp");
            return (value == null) ? "" : value.ToString();
The client:
// WcfClient1: Using a Web service provided by the WcfService1 project (under Web folder), gets and displays a value of
// an OPC item.
using System;
namespace WcfClient1
    class Program
        static void Main()
            var client = new Service1Client();
            // Use the 'client' variable to call operations on the service.
            Console.WriteLine(client.GetData());
            Console.ReadLine();
            // Always close the client.
            client.Close();
What you described should be doable. If you run into any specific issues, let me know and we will try to help.
08 Dec 2014 20:15 #2552 by neilcooley
Hi
Do you have any examples of Windows Service communicating to a Windows Form using WCF?
I am thinking of something along these lines;
Windows Service, ItemChanged event, updates a list with real time values
Windows form via WCF, polls that list and displays the values in a listview.
Neil
