DA Binding
14 Aug 2013 20:56 #1389 by arahming
Replied by arahming on topic DA Binding
This thread can be ceased I stand corrected this will not work as a solution either
thanks
14 Aug 2013 16:07 #1385 by support
Replied by support on topic DA Binding
I am sorry but I do not understand the question. Do you need to connect using just procedural programming model (API) and it does not work? If so, what are the sypmtoms? Or are you asking for a method to *check* (using API) when the server is available and connected?
14 Aug 2013 03:31 - 14 Aug 2013 15:05 #1382 by arahming
DA Binding was created by arahming
I need code that will show an OPC server is alive and cannot connect using the OPC DA client (SISCO AXS4 server). I can however connect using Dabinder in a winform and was wondering if there is a way to do this with Code.. I just need to either check the server is available or check a tag. I have browsed the forum and have found serveral post where people have had issues with the AXS4 server if anyone has found an alternate way of connecting to this it would be appreaciated.
Last edit: 14 Aug 2013 15:05 by arahming.
