Advanced Installer auto register QuickOPC
26 Jul 2019 11:53 #7574 by support
OK so please fix your installer so that in the end the registries are both identical.
26 Jul 2019 11:09 #7573 by SZL
The details of the licencing problem: the control appear in form, but not browsing. The error message appear: I have no Multipurpose licence registered.
I follow your description:
The normal registry entries are good (same as the original), but in the WOW6432 section the follownig registry entries are different:
CallerRestrictions
PlatformRestrictions
(my application runs in 64 bit mode)
Thank you!
26 Jul 2019 07:46 #7570 by support
Please describe what you mean by "I have licencing problems with the QuickOPC controls".
Second, to troubleshoot this kind of problems, do it as follows:
- Use REGEDIT on the machine where the license works (e.g. where you have used the License manager), and do File->Export on the two registry keys we are dealing with.
- Do the same on the computer where you have installed the app using your tool and where you have problems.
- Compare the corresponding pairs of files, e.g. using the FC command. They must be precisely the same. Are they?
25 Jul 2019 13:45 #7564 by SZL
I follow this description to build the auto registration into my installation file:
opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...ce-QuickOPC/License_Store.html
I build the setup with Advanced Installer.
So I export my registry entries from the development computer and I integrate the keys into Advanced Installer setup project.
In production computer after the installation I have licencing problems with the QuickOPC controls.
In this case I need execute the QuickOPC installer with custom installation - Production (.NET) and use the licensemanager to activate the QuickOPC product.
The copy of the registry entries from development computer is not enough?
What need I do to make this installer working in production environment?
Thank you!
