licensing
11 Sep 2019 10:35 - 11 Sep 2019 12:59 #7722 by support
Replied by support on topic licensing
the answers are below.
- is EasyUAClient class compatible on Windows Server 2019 ?
The current version (2018.3) has not been tested on Windows Server 2019 (see kb.opclabs.com/Versions ), but it probably works. Windows Server 2019 will be oficially supported in the upcoming version 2019.1.
- the methods client.ReadValue() and client.WriteValue() are compatible on Microsoft Windows Server 2019 build 1809 ?
Same answer as above.
- Can I deploy the application and register license on many Microsoft Windows Servers 2019 build 1809 ?
For the technical pert of it: Yes, with the reservations as above. Whether you are allowed or not to, depends on the type of license. For example, the "Single Developer + Runtime Free" license allows that.
- Can I register the application on server 2019 inside my C# application using LicensingManagement.Instance.RegisterManagedResource() ?
Yes - again with the same reservations as above (Windows Server 2019 will officially be supported in QuickOPC 2019.1).
- The license is for one developer/computer. Can Others developers rebuild the C# project and run in Trial Mode ?
I will assume that you are referring to "Single Developer + Runtime Free" license. As the name says, the trial license is for trying something, before you purchase. For actual development, every developer needs a license (we have "Additional Developers License" or "Site License" for that).
- When I purchase the license how long time to receive the BIN file license ?
Over the Web shop (Share-it): usually in several minutes. With manual process (invoice + bank transfer etc.) - we send the permanent license key in max. one business day after we receive the payment (we ca send a temporary key for the time in between if needed).
Additional information: If you purchase without the "Upgrade Assurance" option, you will be licensed for the current version, plus any version that gets released during the 60 days following the purchase. We expect to release QuickOPC 2019.1 by the end of this September.
Last edit: 11 Sep 2019 12:59 by support.
11 Sep 2019 09:06 #7721 by Giuseppe12
Replied by Giuseppe12 on topic licensing
I will purchase QuickOPC Standard Single Developer + Runtime Free License, €1971, to use in C# code on a console service with .NET Framework 4.7.2 on Visual Studio 2017.
But before I need some information and Your answers :
Giuseppe
20 Apr 2018 13:04 #6248 by support
The license is for versions released by October 7, 2015, and you/the customer are trying to use it with version 2018.1 (5.52, released February 13, 2018, see kb.opclabs.com/Versions ).
20 Apr 2018 12:43 #6247 by giles
licensing was created by giles
Hi my customers installation fails after two hours with "Run time is over the limit in license "Multipurpose". The license you have (most likely trial version) does not provide valid data after certain time period expires. Note that after the component's process is simply restarted, valid data will be provided again. Obtain and install proper license to permanently resolve this error. Component name: "QuickOPC", license IDs: "Multipurpose", version number: 552, release date: 13/02/2018, trial validity: 210 days, option name: "EasyDAClient".
I've given him a install.reg file as follows (activation key removed) he's installing it by double clicking
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Licensing\QuickOpc\Multipurpose]
"Version"=dword:00000004
"ActivationKey"=hex:I HAVE REMOVED THIS
"NotAfter"=hex(b):00,00,00,00,00,00,00,00
"PlatformRestrictions"=hex(7):00,00,00,00
"VersionNumberCovered"=dword:0000021b
"SubjectName"="giles bradshaw"
"RunOnServer"=dword:00000001
"TopicLRUSizeLimit"=dword:7fffffff
"AllPurposeStations"=dword:00000001
"OptionRestrictions"=hex(7):2d,00,53,00,74,00,72,00,65,00,61,00,6d,00,49,00,6e,\
00,73,00,69,00,67,00,68,00,74,00,00,00,00,00
"SerialNumber"=dword:746ee9d3
"IssuerName"="OPC Labs"
"NotBefore"=hex(b):00,00,00,00,00,00,00,00
"ClientLRUSizeLimit"=dword:7fffffff
"ExtraRuntimeStations"=dword:ffffffff
"CallerRestrictions"=hex(7):00,00,00,00
"Hidden"=dword:00000000
"Type"="Ultimate; Single Developer + Runtime Free License"
"ReleaseDateCovered"=hex(b):00,00,36,5d,a3,ba,d0,01
"ID"="Multipurpose"
"RunTimeLimit"=dword:ffffffff
"DataFieldDefinitions"=hex(7):53,00,49,00,5a,00,45,00,3a,00,20,00,38,00,3b,00,\
20,00,4b,00,49,00,4e,00,44,00,3a,00,20,00,74,00,69,00,6d,00,65,00,2f,00,66,\
00,69,00,6c,00,65,00,74,00,69,00,6d,00,65,00,3b,00,20,00,54,00,59,00,50,00,\
45,00,3a,00,20,00,31,00,31,00,3b,00,20,00,4e,00,41,00,4d,00,45,00,3a,00,20,\
00,4e,00,6f,00,74,00,41,00,66,00,74,00,65,00,72,00,3b,00,20,00,00,00,53,00,\
49,00,5a,00,45,00,3a,00,20,00,32,00,3b,00,20,00,4b,00,49,00,4e,00,44,00,3a,\
00,20,00,3b,00,20,00,54,00,59,00,50,00,45,00,3a,00,20,00,37,00,3b,00,20,00,\
4e,00,41,00,4d,00,45,00,3a,00,20,00,50,00,6c,00,61,00,74,00,66,00,6f,00,72,\
00,6d,00,52,00,65,00,73,00,74,00,72,00,69,00,63,00,74,00,69,00,6f,00,6e,00,\
73,00,3b,00,20,00,00,00,53,00,49,00,5a,00,45,00,3a,00,20,00,34,00,3b,00,20,\
00,4b,00,49,00,4e,00,44,00,3a,00,20,00,3b,00,20,00,54,00,59,00,50,00,45,00,\
3a,00,20,00,34,00,3b,00,20,00,4e,00,41,00,4d,00,45,00,3a,00,20,00,56,00,65,\
00,72,00,73,00,69,00,6f,00,6e,00,4e,00,75,00,6d,00,62,00,65,00,72,00,43,00,\
6f,00,76,00,65,00,72,00,65,00,64,00,3b,00,20,00,00,00,53,00,49,00,5a,00,45,\
00,3a,00,20,00,31,00,35,00,3b,00,20,00,4b,00,49,00,4e,00,44,00,3a,00,20,00,\
3b,00,20,00,54,00,59,00,50,00,45,00,3a,00,20,00,31,00,3b,00,20,00,4e,00,41,\
00,4d,00,45,00,3a,00,20,00,53,00,75,00,62,00,6a,00,65,00,63,00,74,00,4e,00,\
61,00,6d,00,65,00,3b,00,20,00,00,00,53,00,49,00,5a,00,45,00,3a,00,20,00,34,\
00,3b,00,20,00,4b,00,49,00,4e,00,44,00,3a,00,20,00,3b,00,20,00,54,00,59,00,\
50,00,45,00,3a,00,20,00,34,00,3b,00,20,00,4e,00,41,00,4d,00,45,00,3a,00,20,\
00,52,00,75,00,6e,00,4f,00,6e,00,53,00,65,00,72,00,76,00,65,00,72,00,3b,00,\
20,00,00,00,53,00,49,00,5a,00,45,00,3a,00,20,00,34,00,3b,00,20,00,4b,00,49,\
00,4e,00,44,00,3a,00,20,00,3b,00,20,00,54,00,59,00,50,00,45,00,3a,00,20,00,\
34,00,3b,00,20,00,4e,00,41,00,4d,00,45,00,3a,00,20,00,54,00,6f,00,70,00,69,\
00,63,00,4c,00,52,00,55,00,53,00,69,00,7a,00,65,00,4c,00,69,00,6d,00,69,00,\
74,00,3b,00,20,00,00,00,53,00,49,00,5a,00,45,00,3a,00,20,00,34,00,3b,00,20,\
3a,00,20,00,34,00,3b,00,20,00,4e,00,41,00,4d,00,45,00,3a,00,20,00,41,00,6c,\
00,6c,00,50,00,75,00,72,00,70,00,6f,00,73,00,65,00,53,00,74,00,61,00,74,00,\
69,00,6f,00,6e,00,73,00,3b,00,20,00,00,00,53,00,49,00,5a,00,45,00,3a,00,20,\
00,31,00,36,00,3b,00,20,00,4b,00,49,00,4e,00,44,00,3a,00,20,00,3b,00,20,00,\
54,00,59,00,50,00,45,00,3a,00,20,00,37,00,3b,00,20,00,4e,00,41,00,4d,00,45,\
00,3a,00,20,00,4f,00,70,00,74,00,69,00,6f,00,6e,00,52,00,65,00,73,00,74,00,\
72,00,69,00,63,00,74,00,69,00,6f,00,6e,00,73,00,3b,00,20,00,00,00,53,00,49,\
00,5a,00,45,00,3a,00,20,00,34,00,3b,00,20,00,4b,00,49,00,4e,00,44,00,3a,00,\
20,00,3b,00,20,00,54,00,59,00,50,00,45,00,3a,00,20,00,34,00,3b,00,20,00,4e,\
00,41,00,4d,00,45,00,3a,00,20,00,53,00,65,00,72,00,69,00,61,00,6c,00,4e,00,\
75,00,6d,00,62,00,65,00,72,00,3b,00,20,00,00,00,53,00,49,00,5a,00,45,00,3a,\
00,20,00,39,00,3b,00,20,00,4b,00,49,00,4e,00,44,00,3a,00,20,00,3b,00,20,00,\
54,00,59,00,50,00,45,00,3a,00,20,00,31,00,3b,00,20,00,4e,00,41,00,4d,00,45,\
00,3a,00,20,00,49,00,73,00,73,00,75,00,65,00,72,00,4e,00,61,00,6d,00,65,00,\
3b,00,20,00,00,00,53,00,49,00,5a,00,45,00,3a,00,20,00,38,00,3b,00,20,00,4b,\
00,49,00,4e,00,44,00,3a,00,20,00,74,00,69,00,6d,00,65,00,2f,00,66,00,69,00,\
6c,00,65,00,74,00,69,00,6d,00,65,00,3b,00,20,00,54,00,59,00,50,00,45,00,3a,\
00,20,00,31,00,31,00,3b,00,20,00,4e,00,41,00,4d,00,45,00,3a,00,20,00,4e,00,\
6f,00,74,00,42,00,65,00,66,00,6f,00,72,00,65,00,3b,00,20,00,00,00,53,00,49,\
00,41,00,4d,00,45,00,3a,00,20,00,43,00,6c,00,69,00,65,00,6e,00,74,00,4c,00,\
52,00,55,00,53,00,69,00,7a,00,65,00,4c,00,69,00,6d,00,69,00,74,00,3b,00,20,\
00,00,00,53,00,49,00,5a,00,45,00,3a,00,20,00,34,00,3b,00,20,00,4b,00,49,00,\
4e,00,44,00,3a,00,20,00,3b,00,20,00,54,00,59,00,50,00,45,00,3a,00,20,00,34,\
00,3b,00,20,00,4e,00,41,00,4d,00,45,00,3a,00,20,00,45,00,78,00,74,00,72,00,\
61,00,52,00,75,00,6e,00,74,00,69,00,6d,00,65,00,53,00,74,00,61,00,74,00,69,\
00,6f,00,6e,00,73,00,3b,00,20,00,00,00,53,00,49,00,5a,00,45,00,3a,00,20,00,\
32,00,3b,00,20,00,4b,00,49,00,4e,00,44,00,3a,00,20,00,3b,00,20,00,54,00,59,\
00,50,00,45,00,3a,00,20,00,37,00,3b,00,20,00,4e,00,41,00,4d,00,45,00,3a,00,\
20,00,43,00,61,00,6c,00,6c,00,65,00,72,00,52,00,65,00,73,00,74,00,72,00,69,\
00,63,00,74,00,69,00,6f,00,6e,00,73,00,3b,00,20,00,00,00,53,00,49,00,5a,00,\
45,00,3a,00,20,00,34,00,3b,00,20,00,4b,00,49,00,4e,00,44,00,3a,00,20,00,3b,\
00,20,00,54,00,59,00,50,00,45,00,3a,00,20,00,34,00,3b,00,20,00,4e,00,41,00,\
4d,00,45,00,3a,00,20,00,48,00,69,00,64,00,64,00,65,00,6e,00,3b,00,20,00,00,\
00,53,00,49,00,5a,00,45,00,3a,00,20,00,35,00,30,00,3b,00,20,00,4b,00,49,00,\
4e,00,44,00,3a,00,20,00,3b,00,20,00,54,00,59,00,50,00,45,00,3a,00,20,00,31,\
00,3b,00,20,00,4e,00,41,00,4d,00,45,00,3a,00,20,00,54,00,79,00,70,00,65,00,\
00,20,00,31,00,31,00,3b,00,20,00,4e,00,41,00,4d,00,45,00,3a,00,20,00,52,00,\
65,00,6c,00,65,00,61,00,73,00,65,00,44,00,61,00,74,00,65,00,43,00,6f,00,76,\
00,65,00,72,00,65,00,64,00,3b,00,20,00,00,00,53,00,49,00,5a,00,45,00,3a,00,\
20,00,31,00,33,00,3b,00,20,00,4b,00,49,00,4e,00,44,00,3a,00,20,00,3b,00,20,\
00,54,00,59,00,50,00,45,00,3a,00,20,00,31,00,3b,00,20,00,4e,00,41,00,4d,00,\
45,00,3a,00,20,00,49,00,44,00,3b,00,20,00,00,00,53,00,49,00,5a,00,45,00,3a,\
00,20,00,34,00,3b,00,20,00,4b,00,49,00,4e,00,44,00,3a,00,20,00,74,00,69,00,\
6d,00,65,00,73,00,70,00,61,00,6e,00,2f,00,6d,00,73,00,3b,00,20,00,54,00,59,\
00,50,00,45,00,3a,00,20,00,34,00,3b,00,20,00,4e,00,41,00,4d,00,45,00,3a,00,\
20,00,52,00,75,00,6e,00,54,00,69,00,6d,00,65,00,4c,00,69,00,6d,00,69,00,74,\
00,3b,00,20,00,00,00,00,00
Time to create page: 0.082 seconds
