Working wery slow
28 Mar 2017 05:29 #5040 by support
Replied by support on topic Working wery slow
Sent the analyzer link by email.
There are, however, strange symptoms leading to a possibility that the use of the analyzer won't be of much help. Specifically
a) The fact that you claim that the problem is "... blocking all other threads in the program.". I can't understand how a bug in the client component could cause this. Normally when an operation blocks, it is just the one thread that is affected.
What are the other threads in your app doing?
b) We have a timeout (default to 60 seconds), so even if the server does not respond, the method should return much faster - and not in a time that exceeds 1 hour.
  • veecan
  • Offline
  • Premium Member
  • Premium Member
  • A bad day when you do not learn something new
27 Mar 2017 09:13 #5037 by veecan
Replied by veecan on topic Working wery slow
Hallo
The reason I think it is the client is that my costumer uses a Beijer Electronic OPC server for connecting to a Siemens step 7.
I do not have this equipment so I use a NapOPC server from IPC-DAS fro controling a Wise module.
In both cases we see that after 1 hour 40 minutes and 50 sec (take or leave 5 sec) the system is hanging in the write function.
If a read function is executed before write function, we see no problem other than the extra time used.
I can try to run the analyzer. But it is a long time before tha failure somes.
best regards René
26 Mar 2017 09:51 #5035 by support
It looks more like something on the server side. It would be possible to tell more if you wanted to investigate more, and deploy an OPC Analyzer in between the client and the server. Related info: kb.opclabs.com/How_to_use_OPC_Analyzer .
Is there something that leads you to belief that the problem is rather on the client side?
  • veecan
  • Offline
  • Premium Member
  • Premium Member
21 Mar 2017 22:21 - 22 Mar 2017 10:45 #5020 by veecan
Hallo
The program is hanging in the write function and blocking all other threds in the program.
As I wrote before I have found a workaround by first reading the register and then write to the register.
Doing it this way I have no problems, besides the time used for reading.
best regards René
Last edit: 22 Mar 2017 10:45 by veecan.
21 Mar 2017 08:10 #5015 by support
Does the EasyDAClient.WriteXXXX method return quickly, and THEN the actual write occurs much later, OR does the WriteXXXX method block for that long ?
  • veecan
  • Offline
  • Premium Member
  • Premium Member
20 Mar 2017 14:43 #5014 by veecan
Additional information:
If I read theitem before I write every thing is working fine.
Not sure of version. Have QuickOPC-5.32 and use EasyDAClient.
No loss of memory. Computer reboot before it can run again.
Client and server on same computer.
Do not have another client but can access the OPCserver by webinterface. No problem.
20 Mar 2017 13:53 #5013 by support
1. Are you using OPC "Classic" or OPC UA ?
2. Is your application also using subscriptions?
3. Are you observing some memory or CPU consumption increase on the server side?
4. Are you observing some memory or CPU consumption increase on the client side?
5. If you stop the client and restart it, does it resolve the issue?
6. If you connect a different client at the time your application is showing the slowness symptoms, is the other client working fine, or does it also show the slowness?
7. Is the server and the client on the same machine ?
  • veecan
  • Offline
  • Premium Member
  • Premium Member
20 Mar 2017 13:29 #5012 by veecan
Working wery slow was created by veecan
Halo
I have got a problem.
After running my program using OPC the system gets so slow, but program stil run.
And every time it is a write command and it happens after 1 hour 40 minutes and 50 seconds.
And I have tried against different OPC servers.
Anybody seen same behavior.
Time to create page: 0.065 seconds
