Python examples
20 Feb 2024 17:40 #12562 by support
Replied by support on topic Python examples
21 Nov 2023 13:39 #12401 by support
Note: QuickOPC now supports Python in much better way, cleaner syntax, and public packages (pypi.org/project/opclabs-quickopc/) on Python Package Index . See What's new in QuickOPC 2023.2 for more information. And, over 270 examples are available in the User's Guide!
30 May 2018 06:10 #6381 by support
QuickOPC is exposed to Python via COM, and consuming COM events from Python has turned out to be quite problematic. It might be possible, but you are on your own, currently.
Instead, we suggest to use the "event pull mechanism" - see opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...#Event%20Pull%20Mechanism.html . Semantically, it gets you precisely the same notifications as you would get with events or callbacks, but the coding is different and the activity to obtain the data comes from your side.
There is a Python example right on that documentation page. It looks like this:
# This example shows how to subscribe to item changes and obtain the events by pulling them.
import time
import win32com.client
# Instantiate the client object
client = win32com.client.Dispatch('OpcLabs.EasyOpc.DataAccess.EasyDAClient')
# In order to use event pull, you must set a non-zero queue capacity upfront.
client.PullItemChangedQueueCapacity = 1000
print('Subscribing item changes...')
client.SubscribeItem('', 'OPCLabs.KitServer.2', 'Simulation.Random', 1000)
print('Processing item changes for 1 minute...')
endTime = time.time() + 60
while time.time() < endTime:
    eventArgs = client.PullItemChanged(2*1000)
    if eventArgs is not None:
        # Handle the notification event
        print(eventArgs)
print('Unsubscribing item changes...')
client.UnsubscribeAllItems()
print('Finished.')
29 May 2018 13:54 #6370 by filin
Python examples was created by filin
Hello!
I have a small question. How I can register callback for subscribtion (i mean smth like ItemChanged)?
Do you have any examples for it?
