Use of EasyAEClient
23 Sep 2017 15:44 #5542 by support
Replied by support on topic Use of EasyAEClient
QuickOPC maintains connections to target OPC servers automatically. The connection is created when first needed, and closed some (configurable) time after not being in use any longer. In case you create OPC A&E subscriptions, they indicate an intent to be subscribed, so in this case the connection is kept open, until you unsubscribe all of them. This behavior cannot be changed, and there is no additional call to disconnect explicitly.
Related info: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...0OPC%20failure%20recovery.html
Regarding the first question: The information about whether the server is or is not successfully subscribed is transferred through the same channel as the A&E event notifications themselves. See e.g.: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...html#Notification%20Event.html
Also related:
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...ibing%20to%20OPC%20Events.html
- kb.opclabs.com/OPC_A%26E_Notification_Handler_Pseudo-Code
The following user(s) said Thank You: Millon
22 Sep 2017 10:29 #5538 by Millon
Use of EasyAEClient was created by Millon
I use classic COM EasyAEClient.
Is it possible to know the state of a subscription?
Is it possible to disconnect from the OPC server connected with the ServerDescriptor object ?
