Event on a item doesn't work..
09 Oct 2015 16:12 #3612 by support
Yes,
with the Single Developer + Runtime Free license, you get a single .BIN file that is both for development purposes (by one developer) and runtime deployments.
09 Oct 2015 06:32 #3610 by LaurentzT
Just to be clear: We have 1 bin file and can use this with the licence maganager on both the Development Machine and the Production PC's?
03 Oct 2015 11:50 #3588 by support
The current version is 5.35 (I suggest that you download it and use if you do not have it yet), and the Concepts document for that version is here: www.opclabs.com/files/documents/QuickOpc/5.35/Concepts-QuickOPC.pdf . The same document gets installed with the product.
And, below is the part that describes installing the license:
3.7 License Manager
The License Manager is a utility that allows you to install, view and uninstall licenses.
In order to install a license, invoke the License Manager application (from the Start menu), select “QuickOPC 5.3” in the component drop-down, and press the Install license button. Then, point the standard Open File dialog to the license file (with .BIN) extension provided to you by your vendor.
Note: You need administrative elevated privileges to successfully install and uninstall licenses.
(in Windows 8 and later, you may have to look for the License manager alphabetically, or use the "Search" facility to locate the License Manager in the "Start Menu")
02 Oct 2015 08:40 #3587 by LaurentzT
hello,
Thanks it works now. So I bought the licence but this link isn't working:
www.opclabs.com/files/documents/QuickOpc/5.33/Concepts-QuickOPC.pdf
Can you give me the directions to install the Licence file? I have the .bin file
28 Sep 2015 11:13 #3575 by support
I think that the main issue is in the fact that the event notification handlers are not hooked to the EasyUAClient object. This is done using the "WithEvents" keyword; in addition, the object then needs to be declared in a global scope (not inside a function). For example, our Excel VBA example looks like this:
' Declare an EasyOPC-UA component
Public WithEvents Client As EasyUAClient
Private Sub SubscribeCommandButton_Click()
    ' Create the EasyOPC-UA component
    Set Client = New EasyUAClient
    Dim MonitoringParameters As New UAMonitoringParameters
    MonitoringParameters.SamplingInterval = 1000
    ' Define OPC node IDs
    ' For "states", we use names of cells where the values should be updated
    Dim MonitoredItemArguments1: Set MonitoredItemArguments1 = CreateObject("OpcLabs.EasyOpc.UA.OperationModel.EasyUAMonitoredItemArguments")
    MonitoredItemArguments1.EndpointDescriptor.UrlString = "http://opcua.demo-this.com:51211/UA/SampleServer"
    MonitoredItemArguments1.NodeDescriptor.NodeId.ExpandedText = "nsu=http://test.org/UA/Data/;i=10845"
    Set MonitoredItemArguments1.MonitoringParameters = MonitoringParameters
    MonitoredItemArguments1.State = "D2"
    Dim MonitoredItemArguments2: Set MonitoredItemArguments2 = CreateObject("OpcLabs.EasyOpc.UA.OperationModel.EasyUAMonitoredItemArguments")
    MonitoredItemArguments2.EndpointDescriptor.UrlString = "http://opcua.demo-this.com:51211/UA/SampleServer"
    MonitoredItemArguments2.NodeDescriptor.NodeId.ExpandedText = "nsu=http://test.org/UA/Data/;i=10853"
    Set MonitoredItemArguments2.MonitoringParameters = MonitoringParameters
    MonitoredItemArguments2.State = "D3"
    Dim MonitoredItemArguments3: Set MonitoredItemArguments3 = CreateObject("OpcLabs.EasyOpc.UA.OperationModel.EasyUAMonitoredItemArguments")
    MonitoredItemArguments3.EndpointDescriptor.UrlString = "http://opcua.demo-this.com:51211/UA/SampleServer"
    MonitoredItemArguments3.NodeDescriptor.NodeId.ExpandedText = "nsu=http://test.org/UA/Data/;i=10855"
    Set MonitoredItemArguments3.MonitoringParameters = MonitoringParameters
    MonitoredItemArguments3.State = "D4"
    Dim arguments(2)
    Set arguments(0) = MonitoredItemArguments1
    Set arguments(1) = MonitoredItemArguments2
    Set arguments(2) = MonitoredItemArguments3
    ' Subscribe to OPC monitored items
    Call Client.SubscribeMultipleMonitoredItems(arguments)
End Sub
Private Sub UnsubscribeCommandButton_Click()
    ' Unsubscribe from all OPC monitored items
    Call Client.UnsubscribeAllMonitoredItems
End Sub
Private Sub Client_MonitoredItemChanged(ByVal Sender As Variant, ByVal E As OpcLabs_EasyOpcUA.EasyUAMonitoredItemChangedEventArgs)
    ' Update the value in the cell. The cell name is passed to us in the State property.
    Range(E.arguments.State).Value = E.AttributeData.Value
End Sub
25 Sep 2015 13:53 - 25 Sep 2015 13:53 #3573 by LaurentzT
File Name: TestOpcUa.rar
File Size:22 KB
File Size:22 KB
had to insert it. :)
Last edit: 25 Sep 2015 13:53 by LaurentzT.
25 Sep 2015 13:46 #3572 by support
Hello - I do not see the file; besides selecting it, haven't you forgotten to actually insert it?
25 Sep 2015 13:42 #3571 by LaurentzT
Here is my test accdb.
Thanks!
25 Sep 2015 13:31 #3570 by support
Can you post the MDB file here (zipped)? I want to check the remainder of the such - such as whether the events are hooked to the client object.
25 Sep 2015 12:51 #3568 by LaurentzT
I'm using your object in Access 2010.
I try to catch a event but he doesn't enter the function. Here is the code I use now:
Dim MonitoredItemArguments1 As EasyUAMonitoredItemArguments
MonitoredItemArguments1.EndpointDescriptor.UrlString = "opc.tcp://STP-OPC-01.domain1.local:55101?None?opcfoundation.org/UA/SecurityPolicy#None"
MonitoredItemArguments1.NodeDescriptor.NodeId.ExpandedText = "ns=3;s=s7400.db500.16,r"
Dim arguments(0)
Call client.SubscribeMultipleMonitoredItems(arguments)
Call client.WriteValue("opc.tcp://STP-OPC-01.domain1.local:55101?None?opcfoundation.org/UA/SecurityPolicy#None", "ns=3;s=s7400.db500.16,r", 4) 'Real here I set a new value
' Schedule an update. The cell name is passed to us in the State property.
Dim str As String
str = "" ' doesn't enter the breakpoint here.
' ValueString = """" & Replace(Replace(E.AttributeData.Value, """", """"""), "'", "''") & """"
' Application.OnTime Now, "'Sheet1.UpdateCell """ & E.Arguments.State & """, " & ValueString & "'"
End Sub
I also get a error on this line:
Error: Object Required.
When you can resolve this for me I will be able to use this in production and buy the control.
Thanks!
