Browsing error
06 Jun 2017 15:35 #5196 by support
Replied by support on topic Browsing error
I am sorry but I do not really know which part is not clear. The instructions say to put a couple of lines "before the very first OPC operation is attempted". So, somewhere in your code, before you start doing something OPC-related, put e.g.
EasyDAClient.ClientParameters.UseCustomSecurity = false;
EasyDAClient.ClientParameters.TurnOffActivationSecurity  = false;
EasyDAClient.ClientParameters.TurnOffCallSecurity = false;
and test. If that does not help, vary the false/true combinations.
06 Jun 2017 15:27 #5195 by I-Tecnology
Replied by I-Tecnology on topic Browsing error
Please, can you explain better how to use this parameters with Quicklab 5.35?
I have a class for comunication with PLC, my OPC object is not directly called in a form.
thanks.
06 Jun 2017 06:13 #5194 by support
Yes, this has to do with (D)COM security.
Version 5.11 is quite old, and some of the settings might have changed since.
Please read www.opclabs.com/forum/connections-reconnections-com-dcom/124...mote-machines-via-code?start=0 , and specifically (quoting : )
Can you please try to assign different combinations to following static properties - in the code, before the very first OPC operation is attempted:
TurnOffCallSecurity only has any influence when UseCustomSecurity == true.
05 Jun 2017 14:34 #5193 by I-Tecnology
Hi, I have configured the OPC server (TopServer 5.21), DCOM and all I usually need in my application.
I have installed on the same pc your library 5.11, 5.35, 2016-2.
If I try to browse the OPC server located in the same machine with your demo application, I can subscribe to any tag.
If I try to connect to an OPC server located in another machine, I can subscribe only tags using the rev.5.11. Using the other versions I have the attacched error.
I used the procedure in softwaretoolbox site to configure dcom. Do I need a different procedure to configure DCOM?
PS The licence is enabled for tag browsing.
05 Jun 2017 13:22 - 05 Jun 2017 14:32 #5192 by I-Tecnology
Do I need a different procedure to configure DCOM? do you have this procedure?
Sorry, I used the wrong area for this post. Please not responnd here and delete it if you want. I will re-post it in the right area.
Last edit: 05 Jun 2017 14:32 by I-Tecnology. Reason: Wrong topic
Time to create page: 0.089 seconds
