Are the browseXXX methods recursive?
02 Oct 2014 16:42 #2371 by support
I will answer in more detail in your related post from today. The short answer is that the "Flat" browsing is not something that is implemented in the EasyDAClient object, but has to be supported by the server, which is extremely rare case.
02 Oct 2014 16:24 #2370 by OndrejBlazek
When using BrowseNodes() a NodeFilter can be applied.
One of the options for NodeFilters is "DABrowseFilter.Flat" which supposedly returns all Leaves nodes from a flattened version of the AddressSpace.
This should have a similar effect to a recursive browse but I was not able to get it to work correctly. When I try browsing with the "DABrowseFilter.Flat" option, the result is always empty.
20 Oct 2013 14:46 #1497 by support
No. If you need to recurse into the sub-branches, you need to code it yourself. It is quite easy. There are some examples available already, e.g. in the QuickOpcCSharpExamples (or QuickOpcVBNETExamples) solution, under Console/BrowseAndReadValues, you will find:
// BrowseAndReadValues: Console application that recursively browses and displays the nodes in the OPC address space, and
// attempts to read and display values of all OPC items it finds.
using System.Diagnostics;
using JetBrains.Annotations;
using OpcLabs.EasyOpc;
using System;
namespace BrowseAndReadValues
    class Program
        const string ServerClass = "OPCLabs.KitServer.2";
        [NotNull]
        static readonly EasyDAClient Client = new EasyDAClient();
        static void BrowseAndReadFromNode([NotNull] string parentItemId)
            // Obtain all node elements under parentItemId
            var nodeFilter = new DANodeFilter();    // no filtering whatsoever
            DANodeElementCollection nodeElementCollection = Client.BrowseNodes("", ServerClass, parentItemId, nodeFilter);
            // Remark: that BrowseNodes(...) may also throw OpcException; a production code should contain handling for it, here
            // omitted for brevity.
            foreach (DANodeElement nodeElement in nodeElementCollection)
                Debug.Assert(nodeElement != null);
                // If the node is a leaf, it might be possible to read from it
                if (nodeElement.IsLeaf)
                    // Determine what the display - either the value read, or exception message in case of failure.
                    string display;
                    try
                        object value = Client.ReadItemValue("", ServerClass, nodeElement);
                        display = String.Format("{0}", value);
                    catch (OpcException exception)
                        display = String.Format("** {0} **", exception.GetBaseException().Message);
                    Console.WriteLine("{0} -> {1}", nodeElement.ItemId, display);
                // If the node is not a leaf, just display its itemId
                else
                    Console.WriteLine("{0}", nodeElement.ItemId);
                // If the node is a branch, browse recursively into it.
                if (nodeElement.IsBranch &&
                    (nodeElement.ItemId != "SimulateEvents") /* this branch is too big for the purpose of this example */)
                    BrowseAndReadFromNode(nodeElement);
        static void Main()
            Console.WriteLine("Browsing and reading values...");
            // Set timeout to only wait 1 second - default would be 1 minute to wait for good quality that may never come.
            Client.InstanceParameters.Timeouts.ReadItem = 1000;
            // Do the actual browsing and reading, starting from root of OPC address space (denoted by empty string for itemId)
            BrowseAndReadFromNode("");
            Console.WriteLine("Press Enter to continue...");
            Console.ReadLine();
The following user(s) said Thank You: byteslash
18 Oct 2013 12:01 #1495 by byteslash
suppose i have a structure like:
Greenhouse
-var1
-var2
-Elements
-var3
-var4
will BrowseXXXX return (var1, var2, var3, var4) or (var1, var2,Elements) ? meaning, will these extend automatically all nodes or not?
